![]() | Home > Puma (Tdci) > Defender Trail-Air System (the TPMS and Reversing Camera) |
draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49 ![]() ![]() ![]() |
It does replace the whole Rear View Mirror, and mounts on the screen, instead of from the roof. It has a plastic cover that clips in to the old mirror mount. |
System: Fitted (well, except the Pressure monitoring sensors.
Photo's to Follow ![]() |
Could you measure the internal rear mirror? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Hi Daniele,
The new mirror is 260mm x 60mm. The original one was 195mm x 60mm Dave. |
Thanks Dave, Have you problem with the sun shields (the two sun wings)? Waiting photos ![]() ![]() Daniele Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
darwin1 Member Since: 03 Apr 2011 Location: Worldwide Posts: 28 ![]() |
I would like to see pictures of the system installed as well.
thanks |
Lordsmut Member Since: 28 Nov 2015 Location: Bucks Posts: 23 ![]() ![]() ![]() |
Still no piccys 4 years on!
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
