Home > Td5 > Seized ABS sensor removal
Lancerdoc999
I am stripping my Defender 2000 Salisbury rear axle for cleaning and swap to new chassis and am trying to remove the ABS sensors. Both sensors are properly seized into the end of the axle casing. The little copper bushes are in there somewhere!
Can I use a bit of wood on the outer part of the sensor and "whack" it out or will this damage it? I don't want to have to buy a new set due to cost if can help it. Is there another way of doing this. Grabbing the rear portion and wiggling it out probably won't work.
Thanks for advice
Post #723663 15th Aug 2018 8:16pm
Lancerdoc999
bump
Post #723712 16th Aug 2018 6:15am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Just get a pry bar and put it under the lip and lever it out. If that does not work vice grips and twist it out. If you damage it, replace it. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #725491 26th Aug 2018 4:38pm
