Home > Technical > 10AS immobiliser question |
you have pm
15th Aug 2018 4:51pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17319 |
The eka code does not turn the immobilisef off permanently, you have to use it every time.
Having read of your problems in your other thread I strongly recommend that you turn off the passive immobiliser using a diagnostic tool to see if that solves the problem and to narrow down the problem area. |
15th Aug 2018 5:23pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Yeh just deciding wether I get another nanocom after I sold mine years ago, or the gap Bluetooth one, the nanocom seems to do slightly more like eka details etc, but I like the idea of iPad or iPhone programming with the gap tool.
JD 2008 TDCi 2.4 XS CSW |
15th Aug 2018 5:39pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 731 |
The GAP tool can also show you these details now. They do get upgraded from time to time so be sure to check.
And yes, using an smartphone or tablet is quite convenient and you aren't limited by a wire attached to the OBD to do your thing, you just have to be within a reasonable range. Pretty good on very hot days with the sun beating down on you. |
16th Aug 2018 1:43am |
I had a quick PM with PatGAPInnov who I think makes the Gap tool, but not 100% sure and he said the EKA code info (and possibly other info like that) are not read by the tool.
16th Aug 2018 6:51am |
