Double CV 300Tdi front prop
I've got an equippe4x4 (The Italian company) double CV HD front propshaft for a 300Tdi 90. came off of my old 90, done about 8000 miles.
Comes with the drive flange for fitting to an LT230 t'box; However....The drive flange is brand new. I thought it was a normal disco2 type (maybe it is?) but the bolts don't line up with the holes in the back of the propshaft (I left the original flange on my old 90 when i sold it... )
So, this one will either need drilling, or the propshaft drilling, or get a D2 flange. the outside diameter of the flange is the same as the propshaft end.
I had it on my 90 when I had a stupid 'merican lifted-to-the-sky rock crawler type suspension setup, and with a 5" or so lift I had bad vibrations, this shaft sorted it completely. but I got fed up with fighting the 90 to drive in a straight line, so came back down a bit closer to earth with some HD OME's.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
