![]() | Home > For Sale & Wanted > Tdci improoved Manifold to turbo gasket |
Charlie Spitfire Member Since: 16 May 2015 Location: Chartres Posts: 55 ![]() ![]() ![]() |
Jake, I have a 2008 2.4 Defender 90. Its chipped by ALIVE tuning. Normal top speed for a Defender I believe is 86 mph. I was doing 90 something for several hours on the auto route in the middle of the summer and I cooked (distorted the flat face) of my manifold. After which it was all horrible blowy and wheezy.
The fix I found on found on here. 1) Remove the shiny ali heat shield that goes around the turbo charger. This is straight forward. Loacte all the bolts, make sure you have the correct spanners, take it off. 2) Then there is a metal bracket that runs fore and aft on the engine block that holds (1) in place. Same thing. Find the bolts. Find the spanners. Take it off. To be noted that the bolt nearest the cab often works itself lose, rattles and then falls out. Mine is gone but someone more fastidious than me would loctite it into place. 3) Locate the exhaust manifold that runs between the engine block and the turbo. If it is blowing you should be able to hear it wheeze when your friend blips the throttle and there ought to be soot around where it is blowing. 4) For this manifold locate the bolts, engine side and turbo side, find the correct spanners ie make sure you have all the tools to remove all the bolts before you start, and remove it. If I remember correctly one bolt has to be done from below. I had to use several socket wrench extenders and a friend to get to this. 5) Manifold has to go to a machine shop to be refaced. I thought about doing it at home but I don't have the skill set to hand file a manifold completely flat. So I found someone with a machine to do this. 6) Reassembly is the reverse of the above but with the new thicker gasket. I daresay that there is a torque setting for each bolt we just did them up firmly but not firmly as you possibly can so as not to strip something. I have a torque wrench but I dont know how to use it. I am not very mechanical but this was relatively straight forwards for me to do although I did need a friend to help me. |
When mine first started to blow I took it to Land Rover and they replaced the gasket. It was blowing again within a hundred miles.
To just replace the gasket you have to remove the heat shroud and at least loosen all the bolts. From what I can remember you have to pretty much dismantle it all. Its not hard if you can find someone to help you and if you make sure you have all the tools before taking it apart. You can take the shroud off and leave it off whilst you are figuring out how to tackle the manifold. |
