Home > Puma (Tdci) > Heater on cold but blowing out warm air
johnnyd
If I set the temperature control to cold, the vents are still blowing out quite warm air of recent, temperature gauge on dash is reading normal, what has happened and how can I adjust it?
JD 2008 TDCi 2.4 XS CSW
Post #723258 13th Aug 2018 5:28pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Probably your heater control valve leaking a little, letting some of the hot coolant into you heater matrix when the valve should be making. Common issue. Do a search Smile
Thumbs Up
Post #723266 13th Aug 2018 6:15pm
johnnyd
I had just topped up the coolant level to possibly above the max line........is there a connection there?
Post #723267 13th Aug 2018 6:19pm
zsd-puma
It wont be the slight overfill in the coolant. It'll be the control valve failed. Get someone to operate the hot/cold control and see if the cable operates the valve under the bonnet. If it doesn't then your cable has come off the back of the rotary control on the dash, if it does then your heater valve has had it.
Post #723340 14th Aug 2018 12:41am
pannawonica
Australia
My heater did the same thing last week! However it was the control cable that had slipped so on cold it was still a bit open! Very Happy Thumbs Up
Post #723344 14th Aug 2018 4:28am
HardCharger
Check to where the control cable links to the valve. Sometimes its not down fully coming from open. Simply push it down and all will be well.
Post #723345 14th Aug 2018 5:04am
Grenadier
Zsd is a far more knowledgable member than me, but it's not necessarily failed if the cable is still attached. Mine was stuck, so a little bit of lube/WD40 on the various moving parts, plus squirted down the engine bay end of the cable and pulled in/out a few times, now works fine!
I promise that's the only long thing I was lubing and pulling back and forth Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #723353 14th Aug 2018 6:58am
As ZSD says either the cable operating the heater valve has become maladjusted, most likely at the valve end (but the possibility of breakage at the knob end (if I'm allowed to say "knob end" on a family forum) cannot be totally ruled out), or else the heater valve has broken up internally.
Puma heater valves are notorious for being about as cheap and tacky as it is possibly to get but cost a fortune from JLR. Elsewhere on the forum a link was recently posted to the same valve (now also inflicted upon Citroen owners and a few others) at a much more reasonable price.
Post #723374 14th Aug 2018 9:12am
Caterham
my understanding is that replacement heater valves kept defenders being built for the last few years. building them was at a loss but replacement heater valves more than covered the losses.
Post #723378 14th Aug 2018 9:35am
johnnyd
lol 2008 TDCi 2.4 XS CSW
Post #723381 14th Aug 2018 9:38am
Caterham
good luck with the fix.
I just had to push my valve a little further manually as the cable has become mal-adjusted.
I suspect what I'll need to do is get the outer sheath and unclip it near the valve and move it towards the valve and then clip it back on again (I'm hoping that's all it'll need) ?
Post #723382 14th Aug 2018 9:40am
johnnyd
OK just had a quick look, the lever operates the valve OK and fully opens (hot) but the valve is reluctant to fully close again, I can push it to fully closed by hand so there is enough cable to allow the movement, is the valve spring loaded to one of the positions at all, or is it fully dependant on the cable movement, ie if the valve is sticky the cable does not have enough force to fully close the valve. Can the valve be serviced or is it caked up for life ?
Post #723397 14th Aug 2018 10:57am
No spring, totally dependent upon the cable.
No, it cannot be serviced. It is however very satisfying when you stamp on one and then throw it in the bin (take it off the metal bracket first or you'll hurt your foot)!
Post #723408 14th Aug 2018 12:08pm
johnnyd
I had a feeling that would be the case......I'll leave it for now I think given autumn is approaching, I'll do a bit of jiggling to see if I can uncrud it at all......
Thanks all 2008 TDCi 2.4 XS CSW
Post #723412 14th Aug 2018 12:31pm
jamaica
Argentina
Hi there!!I've got the same problem with my Puma heating. The system would not shut and warm air keeps heating the cabin.
I've bought the valve and change it today, before that I have checked behind the inside front panel if the cable was ok and still attached to the control dial.
After changing the valve for a new one LR original, can't tell my anger when the thing was still the same as before, hot air keeps flowing inside the cabin but here is the surprise: On the right hand vents the air is cool like it should be when it is ouside air intake selected; but on the left hand vents the air is hot like if the valve didin't have close!!!!
What is happening? Why on one side air intake temp is ok and on the other is hot!!???
I would appreciate if someone who had the same experience share the solution!! Thanks!!!
Post #733739 9th Oct 2018 12:33am
