Home > Puma (Tdci) > Door key or valet key part number? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6628 |
Is the old type key slim enough? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
7th Nov 2017 3:45pm |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
The older one, from like a Defender TD5? Yea, that's a nice size key. Will it work though? Is it the same blade?? I thought the blade was different? |
7th Nov 2017 3:47pm |
Blade is the same as a "Puma" key. It has to be as Land Rover superceded the old keys (AAU8276 and STC4798) to the Puma type (CWE500390)
Try a good local key cutter rather than ordering online, they may have a range of suitable blank blades and you can pick the slimmest. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
7th Nov 2017 3:55pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
I can reccomend Timpsons (usually found in a small ISO container type kiosk outside Tescos)
I broke the key in my pocket a while back (it was cracked anyway) and they were very helpful. Had blanks on the peg ready to go. Think it was £11 all in for a blank and a cut. Their blanks were just flat metal, no plastic ends so nice and slim |
7th Nov 2017 4:09pm |
Nice one! Thanks!
I will try locally first! |
7th Nov 2017 4:12pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
If I have a key number for my door lock, beginning R01XXXX can I take it to someone like timpsons to cut a key, I am assuming not, if not where is a good place to get one from?
JD 2008 TDCi 2.4 XS CSW |
11th Aug 2018 2:58pm |
if you just want the blade, then get any old key cutting place to copy your existing key, if it comes with a plastic top, just hack it off with a knife, the blade usually has a tee shaped bit inside the plastic..
11th Aug 2018 8:14pm |
I don’t have the existing key 🔑 used the keyfob for years then realised the key doesn’t fit the doors.....
11th Aug 2018 8:17pm |
Sorry Johnnyd I was replying to the original post, not realising you'd resurrected one from last year.
If you want to order one from the key number, then a Land Rover dealer would be my first port of call. But one of the specialist locksmiths might be able to cut one from the code. |
11th Aug 2018 9:14pm |
Anyone used this lot ?
https://keysinthepost.com/product/land-rover-key/ JD 2008 TDCi 2.4 XS CSW |
12th Aug 2018 11:06am |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
I could be wrong, and hopefully someone will advise if I am, but I understood that if you have the round tag with the key number on it then you can order replacement keys from LR dealers. However, I would be cautious in assuming that the number you have is the correct one if the key you have wont open the door as it is possible the door or ignition lock have been changed at some time in the past without changing all the locks. When I bought my DCPU I had the same problem you have, the pair of keys I had both worked in the ignition but neither would work in the door locks. I found that it was my ignition lock that had been replaced previously so simply bought a replacement ignition lock & door lock barrels & fitted new matching locks all round for about £80.
12th Aug 2018 2:13pm |
Yeh I am trying not to pay 80 quid to a dealer for a key if I can pay 10 quid for the same thing
12th Aug 2018 4:34pm |
Ordered two keys from here https://keysinthepost.com/product/land-rover-key/ just supplying them with the key number and they arrived this morning, both keys work a treat....
FYI JD 2008 TDCi 2.4 XS CSW |
16th Aug 2018 10:03am |
