![]() | Home > Puma (Tdci) > Turbo Overboost |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17728 ![]() ![]() ![]() |
It would certainly suggest to me that the problem is not the vanes in the turbo sticking (unless they only do it when hot, of course). I would be more inclined to look towards the actuator or wiring harness, or sensors.
Yeti110 Member Since: 04 Jan 2018 Location: Skåne Posts: 27 ![]() ![]() |
Thank you Blackwolf.
How could I check either the actuator or the harness? I don't think it could be the vanes sticking. it only happens occasionally, usually when I'm overtaking a massive truck with a black Audi behind me. |
For the harness all you can really do is inspect it carefully, paying particular attention to the places where it touches the engine, mounting brackets, or anything else.
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Can Turbo Overboost P0234 fault code not be related to a leak in intercooler or pipes? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Yes, that's what I read elsewhere on this forum. The intercooler pipes I have renewed, to rule them out.
I will check the wiring harness to see if there is anything visually wrong. Thanks for the replies. The problem I have here in Sweden. Particularly where I live, is Defenders are very rare. Which means specialists do not exist. A main dealer charges 200 pounds an hour for diagnostics. Its cheaper for me to replace the less costly items in the hope I get lucky. The downside is that it is a hit and miss process and may result in a new turbo......hopefully not though. |
Stu_XS Member Since: 22 Jul 2018 Location: Hampshire Posts: 86 ![]() ![]() ![]() |
I don't know the Puma turbo's too well but I've seen plenty of overboost scenario on VAG engines and it is normally the vanes stick when you are on full throttle acceleration heading down a slip road or something.
The vanes go the full extent of travel and jam in that position momentarily. I'm not suggesting or condoning this method but you get the idea. I think you can buy products designed for this job these days. Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
