![]() | Home > In Car Electronics > Rca cable question |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
I have damaged one of the RCA cable endings going from my head unit to my amp - resulting in one of the rear speakers not working
now i know RCA cables aren't expensive but to tear the whole dash apart lift carpets etc is a faf... Somehow the end of the RCA (the 'plug') got squished / stretched this is the cable in question, can i just buy a new 'rca end' and crimp / solder it together? Or even buy the same again, cut the end off and splice it on? I have the 4000 series from headunit to speaker amp and 6000 series RCA from headunit to sub amp.. ![]() Click image to enlarge |
I used to use Rockford fosgate separate rca plugs back in my stereo days but they were a bit of a faff for not much gain so I gave up on them. Not sure if they are still available but they used to be. Ray
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20765 ![]() ![]() |
Rockford Fosgate maybe on car audio direct, I think I saw some on there at some point but limited in range.
A few can in some circumstances be too big, the Stinger version pictured - the plugs on there are very compact but but some do stick out quite a bit. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
I have a Hertz HDP4 mounted on the drivers side and a HDP1 mounted passengers side on some trimmed plywood...
When i was forcing the RCA for the HDP4 through its when it got damaged, i quote like how thin the cables are, obviously for the HDP1 i went with something a bit more substantial.. (and drilled a bigger hole) |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
RS have a selection of RCA plugs, I only know as I did the same pulling an RCA through a wall
![]() https://uk.rs-online.com/web/c/connectors/...26&r=f 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
