Home > Maintenance & Modifications > Basic Maintenance Questions. Newbie!
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
I need some clarity/perhaps confidence building LOL. Trying my hand at the first bit of maintenance on the 2014 puma.
Brake Pads front and rear; know how to do this. Have genuine replacement pads in hand
Fuel Filter; know how to do this
Front and rear diff oils; Lucas Gear Oil 75w90 Synthetic. How much to purchase?
Engine Oil; Rotella 15w40 synthetic (looks like I need to purchase 2 gallons?). Purchased new genuine filter.
Gearbox oil change. NO IDEA what to use or how to do this. Can someone weigh in on specifics for me?
Anything else I should consider? 45km on the clock.
I also just wanted to say how much I appreciate the community and all the folks I have PM'd with for the warm welcome and help. Hoping I can return it one day!
Post #721059 2nd Aug 2018 2:12pm
JOW240725
A little light reading for you, might help a little http://www.defender2.net/forum/topic8707.html
Good luck Thumbs Up James
Instagram @suffolk_rovers
Post #721065 2nd Aug 2018 2:47pm
Devon-Rover
The engine oil needs to be 5w-30 with a ford approval of WSS m2C 934B which is ok for your engine as it has a DPF filter the 15-40 rotella isn't compatible.
The axles have a simple drain and level bung for the fill. you are looking at about 1.7 litres to fill and using a good 75W-90 oil.
The gearbox oil is a 75 - 90 full synthetic gear oil I like many use Castrol syntrans multivehicle with no apparent Ill effects. It is 2.2 litres in capacity and imho measuer the right amount and use a long pipe and funnel and fill from the engine bay as it is tight to get to the filler which should be an 8mm hex bit Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #721071 2nd Aug 2018 3:22pm
big110
tell me more about the oil Devon.....the dealer did the last oil change with the 15-40. Should I change it to the 5w-30?
Post #721082 2nd Aug 2018 4:04pm
UtilityTruck
You’re risking damage to the diesel particulate filter using a non approved engine oil. If it were me, I’d change it.
When I changed my gearbox oil I used the LR spec fluid, it was not cheap but for me gave peace of mind. Available as p/n LR006519. In the box is a 1l bottle of Castrol BOT328. 2014 Keswick Utility 2.2
Post #721104 2nd Aug 2018 5:53pm
big110
thanks so much. appreciate the info on both things.
Also, gearbox and transfer case two diff things?????
Post #721106 2nd Aug 2018 6:09pm
UtilityTruck
So your gearbox gives you your 6 forward/1 reverse gear. The transfer box is bolted to the back and has two ratios- high and low. These act ‘in series’ with the main gears to effectively give you 12 forward and 2 r verse gears.
So yes, different things with different oil specs/capacities. 2014 Keswick Utility 2.2
Post #721110 2nd Aug 2018 6:21pm
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
When I first serviced my 2.2 2012 Puma I put together this list of oils & capacities:
After studying information online and consulting Opie Oils for advice, Concluded that the following oils are appropriate:
Engine 7 litres
For the engine equipped with DPF, oil needs to be 5W-30 to spec. Ford M2C934-B (low SAPS).
Opie oils has several. Selected Millers XF Longlife C1 5W-30 Synthetic.
Gearbox 2.2 litres
Handbook says Castrol BOT130M but this is not generally available. It is a synthetic 75W/90 GL-4 spec.
Selected Castrol Syntrans Multivehicle 75W-90 GL-4 synthetic .
Transfer Box 2.4 litres
Handbook recommends Castrol Syntrax 75W-90 or equivalent.
Selected Castrol Syntrax Universal Plus 75W-90 GL-5 synthetic
Diffs 1.7 litres each
Handbook recommends Texaco Geartex EP 85W/90 or equivalent.
Opie Oils recommended Castrol Syntrax Universal Plus 75W-90 GL-5 synthetic
Post #721123 2nd Aug 2018 7:29pm
Devon-Rover
So gearbox is the right bottle Tbox and axles is the LH bottle as a recommended oil. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #721155 2nd Aug 2018 10:37pm
The Sintopoid on the left there is what I used in my axle just the other day. Thumbs Up
A 1L Sealey (or similar brand) fluid transfer pump really helps to get the accurate 1.7L in but check you're on level ground too. $W33T $0U7H3RN $UG4R
Post #721157 2nd Aug 2018 10:41pm
