![]() | Home > Puma (Tdci) > Sagging front and upgrade suggestions |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
Hello,
I have a 2013 Defender 90 Station Wagon with OEM springs and shocks, I have recently noticed the front right suspension sagging and the fronts are lower than the rear suspension compared to my 2016 Adventure. The 90 has front mantec bumper with winch along with A bumper and offroad lights on the front and roofrack. I have contemplated replacing the springs and shocks for a more durable setup without making the ride harsh. What would you suggest? I have had a lock at Fox Shocks however I cannot find a replacement springs that suite it because I dont want to life my 90. 2016 Defender 90 Adventure Edition |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
Check if you can see the colours on the front springs (assuming they're genuine). If they're blue/yellow or blue/green then you have 2 higher LR spring rates to upgrade to - 110 front or 110 HD front. They will give the stiffness to hold the front up without the lift. A nose down stance unloaded is the factory position, but as you have a lot of extra weight on the front the springs may not have been upgraded also?
Part numbers in here: http://www.red90.ca/rovers/springinfo.html |
