![]() | Home > Camping, Caravanning and Holidays > Al-Ko hitches with Defender tow balls |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17724 ![]() ![]() ![]() |
I am not a caravan expert but the only Al-Ko hitches I have ever come across differ from a standard 50mm ball only in that the neck of the ball is slightly taller to accommodate the deeper socket of the damped coupling.
These will fit in place of the normal 50mm ball coupling with no problem at all (just remember not to grease them). If you were to fit a Dixon Bate adjustable hitch you could put the Al-Ko ball on one slider and a standard greasy ball on another and just swap them over. |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
The only reason the alko is not compatable with the defender is the spare wheel. Buy an alko towball, then you will need to either 1) hitch up with the back door open, then close the door or 2) remove the handle part of the alko and buy a removable handle so the you can hitch up with the door closed.
I'll take some pics of mine later for you if I gat a chance. V8 90...WIP |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
I tow a caravan with an ALKO hitch with a Defender with a rear mounted spare wheel and I have no problems. Admittedly, I have a Dixon Bate adjustable tow bar, which may make a difference. Whatever tow bar you have you will need to buy an ALKO tow ball to fit the hitch this type of tow ball has a longer neck.
Whatever you do not try to hitch up a Stabilised ALKO hitch to a tow ball that has been greased if you do the stabilising pads in the hitch head will be ruined and you will have to have them replaced. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
I have a D-B hitch and a 16mm dropplate used as a spacer only which gives me enough room to couple and uncouple with the rear door open or closed.
If you can find one get a Dixon Bates shock link. Apart from pushing the tow ball a further 2” back it will save breaking the caravan chassis which is relatively common with 4x4 towing caravans.
Brendan |
Sadly not easy to find since Al-Ko took over Bradley/Dixon Bate and discontinued all the good products!
Unfortuntely the DB shock link has been discontinued by Alko. That is why Isaidifyou could find one. Not cheap, they were about £500, however cheaper then sorting out the A frame and caravan chassis.
Brendan |
OE110 Member Since: 23 May 2018 Location: Wales Posts: 14 ![]() ![]() ![]() |
Not entirely sure on what stabilising hitch you have?
All our Bryan James trailers have AL-KO hitches and attach to all vehicles including 90 with standard hitch and a 110 with a droplate without any problems - definitely prefer the AL-KO hitches to the old Bradley style! Perhaps a picture of the hitch might help? |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
AFAIK Most more modern caravans have the standard ALKO hitch. This is the one where the stabiliser handle lifts up to nearly 90° to hitch/unhitch and then folds flat over the hitch head to engage the stabiliser pads on the ball. I find I need to remove the spare from the back door to allow this to be done - I have seen others with the same problem. Someone said hitch up with the door open, in my case I cannot do this as I wouldn’t get the door closed again due to it catching on the jockey wheel. I believe there is or was a kit you could get to replace the stabiliser handle with a removable item, but I didn’t fancy this. My solution was to mount a standard rear door spare wheel mount to my roof rack. At the start of the towing season the wheel goes up there, and comes back down once I’ve finished towing for the season. Not ideal for everyone, but a cheap and secure solution.
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
Here's my AL-KO ball hitch fitted with a spacer ,if I back on to the caravan at a angle I can hitch up without removing the spare or opening the rear door.
![]() Click image to enlarge ![]() Click image to enlarge Not the best picture of my hitch but does show the tpye I have. ![]() Click image to enlarge |
deejayen Member Since: 18 Sep 2017 Location: Inverness Posts: 56 ![]() ![]() |
Thanks very much for all the info and pictures. I think my tow-bar looks the same as Legin's, but I'd need to double-check. Unfortunately, I don't have information on the hitch fitted to the caravan other than it's an Al-Ko Stablising hitch. I think the caravan might be too old to have a "3004" hitch, but perhaps it's a "2004". I've asked the dealer for more details, but they've not yet replied.
The Al-Ko manual seemed to suggest the hitch required a swan-neck hitch, and that a tow-ball which fitted with two bolts wasn't suitable. However, I've since seen that Al-Ko sell a 2-bolt ball with a longer neck than standard, so perhaps that's what I'd need. Having said that, it could be a pain if it's not possible to use the caravan with the spare wheel on the back door of the Defender. The spacer plate might be an option, but I'd be worried if that wasn't completely suitable for towing a caravan. I currently have a Dave Cooper bike rack fitted, and the tow-ball is spaced out from that, and I thought I'd have to get rid of the bike rack coupling. I'm beginning to swing back to the idea of an Alu-Cab roof top tent! |
If you find that the handle fouls the spare wheel, there's absolutely no reason why using a spacer to move the tow ball out slightly wouldn't be completely suitable for towing a caravan. You may even find that your bike rack fitting serves the same purpose, although the rack itself may be a problem with the front of your 'van, depending on model.
Alko hitches, regardless of model, all require what's become known as an Alko tow ball, i.e. one where the ball is slightly higher above the main body, to allow the more bulky hitch head to rotate. There is a standard and readily available two bolt version of this tow ball and they definitely don't just work with swan neck ones. As already mentioned though, tow balls used with Alko hitches must be completely cleaned of grease, or it will contaminate the friction pads and not work properly. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 177 ![]() ![]() ![]() |
I don't tow caravans but I do tow trailers regularly, I have a safari equip swing away carrier this moves the spare wheel about 3" to the drivers side which makes it easier to hitch and unhitch. nobody is perfect but being Scottish is a start
![]() ![]() ![]() ![]() http://www.youtube.com/user/conwy1 |
