Home > Technical > Brake pipe fittings - which thread size?
donmacn
I'm getting myself sorted out to make up some brake pipes. 3/16" pipe I get, metric M10 nuts, but which thread size?
One site I'm looking at has M10x1.0 and M10x1.25...
So, it would be good to get an answer to that - but it would also be good to be pointed in the direction of where such detailed info can be found?
I did try a couple of searches, but couldn't find this specific detail.
Ta.
Edit - and which flare type?? SAE or DIN? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #720465 30th Jul 2018 3:23pm
rallysteve
All M10x1 except for some early master cylinders which have M12 on one port.
Post #720503 30th Jul 2018 6:21pm
donmacn
Thanks Steve - that's a relief! The site I was on said that M10x1.0 was the most popular sized male fitting, so I just went for 25 of those.
Pretty sure my master cylinder is the newer version with the same fitting. Donald
in the past..
Post #720638 31st Jul 2018 10:59am
