Home > For Sale & Wanted > [For Sale] Disco transfer case
excossack
Soon to be for sale will be a disco transfer case. Purchased November 2014(I think it was Simba 4x4) From memory the mileage from the breaker was 80k.
The TC was fitted the to 110 the same time as a replacement gearbox (the noise I thought I had wasn't the TC it was in fact the box). The 110 had done around 178500 in 2014 and is now on almost 210,000 miles.
Drain plug has been re-tapped as the thread stripped. No leaks from the drain plug. Just done a 600mile trip to Scotland and back without issue.
No noticeable bearing noises. Last oil change about 1 month ago by the garage that did the drain plug work(and all other work I don't want to do).
Hand brake holds on hills, so no oil leaking into the drum. (would hold better if I adjusted the cable)
Just awaiting a slot in the local garage to do the work and once removed, it will be for sale.
Might need a new gasket on the inspection cover as there is a little leak around one of the lower bolt heads.
The box has no high/low switch, so if using on a TD5 engine, the ECU won't see the change in ratio.
Has difflock which does work/selects OK after I adjusted the mechanism.
High/Low selects OK and stays in low (unlike the original Defender TC)
Box will be supplied naked, so no hand brake drum, back plate.
I would rather meet up and do a collection that way than have to post as its a heavy lump.
Over to you peeps for comments and suggestions.
Reason for selling, reverting back to a Defender 1.4 ratio box.
Price £130 ono Location 30mins from Chester/M53/M56 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #720541 30th Jul 2018 7:43pm
excossack
Transfer case now removed from my Defender. 1999 Defender TD5 110
Regards
John M0VAZ
Post #721910 7th Aug 2018 8:46am
miker
You say 30 minutes from Chester, in which direction?
Post #722822 11th Aug 2018 10:34am
excossack
Replied via PM. 1999 Defender TD5 110
Regards
John M0VAZ
Post #722841 11th Aug 2018 11:58am
excossack
A cheeky bump - still for sale 1999 Defender TD5 110
Regards
John M0VAZ
Post #726276 30th Aug 2018 2:31pm
