Home > Td5 > Slow TD5
Page 2 of 3 <123>
drinkdrinkdrop
I can move the actuator with mole grips when connected but i’ll Give that a go as well. New TPS and MAF on the way so fingers crossed
Post #719539 24th Jul 2018 9:21pm
stanstorey
I was actually freeing up my waste gate earlier and was unaware just how free it needs to be, so it drops back to centre position itself (as mentioned earlier).
This youtube clip was most helpful...
I just used WD40 as that's all i had to hand, but worked well enough and will keep an eye on it now, it's not a tricky job.
Post #719900 26th Jul 2018 9:48pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
when was the fuel filter last changed? is the pump noisy? what size wheels and tyres? what transfer box ratio etc?
mine on 33's and a 1.2 struggled much over 70. It was over geared. it also went slow just before the fuel pump died. Started foot to the floor to do 70, then a few weeks later 60, then same again and 50.
The injector seals had gone putting carbon in the tank which killed the pump and blocked the filter. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #719909 26th Jul 2018 10:53pm
drinkdrinkdrop
New VDO MAF did the trick so it appears that if running with and without a MAF doesn't affect performance then it's likely gone.
Top speed now 78-79 which I'm putting down to my lift and roof rack with associated gubbins making the aero worse than when it left the factory.
Throttle response is now good in all gears so I'm happy enough. Thanks for all the comments/suggestions
Post #720410 30th Jul 2018 8:52am
Djcla
Hi , did you just gamble on it being the MAF as im convinced mine is also broken and which one did you buy and how much ?
Post #720464 30th Jul 2018 2:09pm
drinkdrinkdrop
Well, it made no difference if it was connected or not so I had my suspicions, to confirm I bought the cheapest one I could find to see what effect it would have and it was worse than no MAF which gave me enough confidence to fork out for a decent one . Got a VDO one from island 4x4 in the end
Post #720486 30th Jul 2018 4:25pm
mk1collector
On the bell auto services web site there is a how to on checking the maf Ray
My build thread
Post #720497 30th Jul 2018 4:52pm
Djcla
I think that says to check the voltage output from pin2 bit I've never quite sussed out how to do that ..
Post #720569 30th Jul 2018 9:18pm
mk1collector
Using a multimeter. Ray
My build thread
Post #720571 30th Jul 2018 9:25pm
Djcla
Haha I meant actually getting a connection on the pins as multimeter prongs are to big
Post #720573 30th Jul 2018 9:32pm
drinkdrinkdrop
Sewing needle through the insulation then touch the multimeter to that has bailed me out a few times
Post #720574 30th Jul 2018 9:35pm
Djcla
thanks for the needle tip, i got it tested and it was showing 2.0v on idle so i guess mine is functioning ok even though when disconnected its not making any difference.
Post #720993 2nd Aug 2018 10:35am
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
Martin 01 wrote:
What did you end up doing to your wastegate Jon ?
Just spray it with lots of lube ?
My apologies, just noticed your post.
I disconnected the c clip from the wastegate that holds the actuator rod. I then sprayed lots of GT85 around where the shaft goes into the turbo and kept working it back and forth 'stop to stop' until it would return to centre without either sticking in the open or closed position.
I last checked it about 6 months ago, and it was as free as it had been when I fixed it.
My symptoms were exactly as per the OP's.
Checking it with mole grips won't tell you anything - it needs to be REALLY free.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #723004 12th Aug 2018 11:41am
urkki
Once again, quality electrics cleaning spray in MAF did some cure for mine. After while the magnetic valve and engnine is doing great and strong as ever Smile
Post #726351 30th Aug 2018 8:20pm
NickMc
Never ever poke through the insulation on wiring you heathen! Shocked the only way I would do it is last resort with a Pomona piercing probe and then seal it up with liquid electrical tape.
Back probe the connector instead.
Post #726362 30th Aug 2018 8:41pm
Page 2 of 3 <123>
