Home > In Car Electronics > Removal/Replace Stock Cig Lighter Plug 2014 110
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
Id like to swap the stock 12v lighter socket for a dual USB charger...
How do I access the lighter to remove the stock one?
I found this post- cant tell if it needs to be this involved in order to get to it or not. Hope to replace with a BlueSea 5amp dual charger.
http://www.defender2.net/forum/topic16968....oval+guide
Post #719965 27th Jul 2018 1:12pm
Al_The_Pal
2015 Defender 110 Puma 2.2 XS CSW Corris Grey
I tried to remove mine in one piece, failed abysmally. There is a metal frame on the back that holds the illumination and acts as a fixing, I ended up bending this while removing it.
I figured it was cheap to replace if i ever went back to stock.
Replaced with a blue sea USB, only thing I wish Iโ€™d have done was to add a suppressor as I get terrible radio interference when charging two devices.
Post #720028 27th Jul 2018 10:06pm
Al_The_Pal
PS that guide looks right, but itโ€™s not that scary once you unscrew the middle panel.
Post #720029 27th Jul 2018 10:08pm
Just remove centre dash, snap off plastic retaining 'tangs' to the rear and it may be tight but will slide out.
Not reallly worth trying to save, they aren't designed to be removable then replace.
.Blue sea are very nice, either 12v or USB versions. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #720034 27th Jul 2018 11:15pm
