Home > Maintenance & Modifications > 10 spline axles to 24 spline
big ives
Have searched and found loads of information but not clear well not for me
My defender 10 spline axles I want to rebuild but second option is to up grade all components to 24 spline
So will new 24 spline components fit into 10 spline casings Question
Many thanks 2016 Discovery 4
1989 90 CSW V8 (fully rebuilt and running like a dream)
1996 defender tray back fully rebuilt/loaded for challenge events
Post #719798 26th Jul 2018 9:06am
ibexman
No new diff or diff centre required
Post #719799 26th Jul 2018 9:13am
big ives
Understand
I will be be using a new diffs and Ashcroft shafts and all new seals etc etc
So will the 10 spline casing taken all these?
Don’t want to get all the bits and bobs and then find out they will not fit, my fear would be the shafts in case there is a different bushing or some thing inside the old casings
Cheers Ivan 2016 Discovery 4
Post #719801 26th Jul 2018 9:25am
Casing will fit OK (unless you've got a really old 6 bolt casing (6 bolt where the stub axle bolts on, newer ones are 7 bolt)
If you do buy a later complete axle, check the radius arm brackets as they're slightly wider on >300Tdi era axles (or get the later arms as well and benefit from the slightly wider bushes, supposed to aid handling)
Post #719803 26th Jul 2018 9:46am
big ives
Diesel Jim
My old axle casing are in excellent condition having been sand blasted and sprayed
Thanks 2016 Discovery 4
Post #719804 26th Jul 2018 9:59am
