Home > Puma (Tdci) > Puma sump pan rotten
Vitesse
Well, my three year old Puma has been perfect with none of the usual troubles reported on this forum.....Except.....the sump pan has some bad rust underneath and looks like it wont be look before a hole appears! Seems like a short time for this to happen?
Anyway, my questions are: has anyone else sfuffered this? Is there a better sump pan I could buy or any other solutions long term.... powder coat a new sump??
I did think about welding this one, but it will probably just rust somewhere else..... Rolling Eyes
thanks for any help.
Brian. 2015 90 XS Santorini Black
Post #719213 23rd Jul 2018 9:02am
zsd-puma
Sounds like it was faulty in manufacture or it's been damaged at some point. Mine still looks like new after 8 years.
Post #719214 23rd Jul 2018 9:05am
Vitesse
Ah..thank you. Thats interesting. Yes, possibly although it has never been off road so maybe a large stone or something has hit it off the road. The sump pan is showing signs of slight rust all over the front. Like the paint is very thin.... The worse patch is right underneath. 2015 90 XS Santorini Black
Post #719215 23rd Jul 2018 9:09am
Organised Chaos
United Kingdom 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
On the third one at the moment, the first one was replaced under warranty for the prop shaft problem, the second one lated about 7 years then started weeping oil, the third one has been on for a couple of years now but gave this one a good coat of stone chip paint.
Post #719218 23rd Jul 2018 10:06am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
This is quite a common problem on a lot of cars now.
Mk6/7 Transits suffer badly with rusty sumps, as do a lot of Vauxhall’s,
Once you get a few stone chips, and the road salt creeps in over winter, it doesn’t take much to start them rusting.
It’s just down to cheap part manufacturing, cost cutting etc,
Compare a modern sump, to a Series 1 sump.... Shocked
Best thing to do is give the front face a good coat of Waxoyl, or like above give it a coat of stonechip Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #719234 23rd Jul 2018 12:28pm
Vitesse
Okay. Thanks for all the advice. Thumbs Up 2015 90 XS Santorini Black
Post #719235 23rd Jul 2018 12:34pm
ericvv
Post #719238 23rd Jul 2018 12:44pm
zsd-puma
The FIRE engine on the Fiats used to rot the sump from he inside out. Laughing
Post #719276 23rd Jul 2018 4:12pm
I think my last one I Dinitrolled, lasted for years and years but eventually leaked at the gasket.
Which is not corrosion related at all. KEEP CALM AND Drill ON
Post #719277 23rd Jul 2018 4:13pm
A lot to be said for under trays Whistle
Post #719288 23rd Jul 2018 5:00pm
Vitesse
Thanks all. New sump it is with dinitrol plus any other type of protection I can come up with
Post #719388 24th Jul 2018 8:35am
