![]() | Home > Puma (Tdci) > Help wanted dtc p0299 can i erase dtc whilst driving? |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Hi all. Now driving in the middle of France limp mode because of dtc p0299. Can i erase the dtc code whilst driving? a defender from 1984 pretending to be a puma with a touch of Range Rover
Thnx. The question really is. What the lessen evil
![]() 1 driving on a motorway up a mountain with 30 mile an hour 2 park on the side of the motorway which is 130 cm wide 3 erase dtc code whilst diving a defender from 1984 pretending to be a puma with a touch of Range Rover |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
It’s the annoying boost code, pull over erase, and be on your way...
![]() Wanted, Forward Control Anything considered. |
Yeah problem is that not all French motorway have normal safety banks. Some are Just less than 3 feet.... so its quiet dangerous to park the car.
Any ideaa what causes the problem. At least is not temp related. Cooling temp was only 95 degrees when it happened. a defender from 1984 pretending to be a puma with a touch of Range Rover |
Most probably MAP sensor having a moment!
Mine does this once every 6 months or so on a motorway drive, a quick clean does the job, It’s quite a common issue. ![]() Wanted, Forward Control Anything considered. |
Update.
Map sensor haven’t checked. But the studs have come loose again!!!! Between the exhaust manifold and the turbo. I think this could cause the problem. Does anyone concur? Or disagree? Any input is welcome! a defender from 1984 pretending to be a puma with a touch of Range Rover |
Yes, could be loosing pressure at the manifold.
Are you using the TDCI engine? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Yes i’am using a tdci 2.4 engine. Why do you ask? a defender from 1984 pretending to be a puma with a touch of Range Rover
Reading your signature, I wasn’t sure what engine you are running?
Just another question. As i was Reading the workshop manual (what else to do on a camping site in the middle of France in the morning). It said that you have to replace the o ring of the map sensor. How critical is this replacement? I thought to be on the safe side and clean the sensor as well. a defender from 1984 pretending to be a puma with a touch of Range Rover
