Home > Puma (Tdci) > Where have you mounted your fire extinguisher?
cartoonhead
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Corris Grey
I need a fire extinguisher in the front cab of my Puma 130, just wondering where others have mounted them and how (quick fists?)? @tab.travels on instagram
Defender 130 2.2 TDCI
Defender 90 TD5
80" CCV Trialer 4.6 V8 (14CUX)
Stage One V8 109 - 3.5 V8
Stage One V8 109 - 4.6 V8 (GEMS) - in progress
Range Rover L322 4.4 TDV8
Freelander 1 2.0 TD4
Post #717810 15th Jul 2018 12:35pm
discomog
Quick Fist mounts from Brendan. Work a treat for small fire extinguishers.
https://www.4x4overlander.com/product-category/storage/quickfist/ Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #717824 15th Jul 2018 2:08pm
leeds
Things like fire extinguishers are best mounted where access is easily available from outside of the vehicle.
In front cab mounted on the front of the seat boxes. OK might make getting in and out slightly more awkward (depending on size of extinguishers) but does not effect passenger/driver as people do not sit with heels against seat box.
On back door horizontally on top of door handle held on by elastic loops.
Brendan
Post #717825 15th Jul 2018 2:16pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
The back of the cubby box was my favourite place as easily reached inside and out of the vehicle ..
(my new set up sees a large extinguisher in the back of the vehicle under the cupboards - accessible from the back door) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #717830 15th Jul 2018 3:02pm
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
Quick fist horizontally mounted on the back door just above the handle. Where it has the added advantage of being constantly "shaken-up" prior to any potential use.
Regards
TT. "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #717832 15th Jul 2018 3:05pm
Devon-Rover
Quick fist's mounted on the Dog guard Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #717863 15th Jul 2018 6:00pm
cartoonhead
It’s a double cab 130 so I need something in the cab - I can’t do the seat box Brendan as I have some additional speakers down there.
I was thinking of maybe putting it above the grab handle, or maybe upright using the existing bolt for the grab handle, a bit like the RAM mount? https://www.4x4overlander.com/product/ram-mount-adapter/ @tab.travels on instagram
Defender 90 TD5
Post #717865 15th Jul 2018 6:03pm
Thon
Safety Devices 2.5kg (I think) using its own mount, bolted to the front of my MSS cubby box. The cubby is an older version without the cup holders or single DIN attached, and luckily just clears the gear and transfer levers. I prefer to be able to grab the extinguisher from the drivers seat if possible.
Post #717879 15th Jul 2018 7:01pm
