Home > Maintenance & Modifications > Fuel filter bolts changed - recommended! |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Done mine a few months back. 2011 build looked like they were recovered from the Titanic.
Replaced mine with stainless bolts and plenty of anti corrosion paste applied. Especially cover the front bolt it gets all the spray and muck. |
13th Jul 2018 7:28pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
I don’t think it helps that the holes are slotted so there is space for cruddy water to sit in there and rust up the bolts. 2014 Keswick Utility 2.2
13th Jul 2018 8:27pm |
Yep you're right there. I fitted bigger washers in a attempt to try and stop this. Time will tell.
13th Jul 2018 8:33pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 388 |
Good advice.....I checked mine which are three years old and were slightly corroded. Covered them in copper grease.... will order replacements though 2015 90 XS Santorini Black
17th Jul 2018 1:10pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17559 |
Wow, over £3 each for an M8x100mm bolt.
You can get A2 stainless for less than £1 each. |
17th Jul 2018 5:20pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 |
I haven't changed mine, but I did clean up and well Dinitrolled them.
Never had an issue this way, if I was to change I'd go stainless in this situation as they are nothing load bearing in any way. With some anti corrosion block they'd be fine. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
17th Jul 2018 6:49pm |
