Home > Puma (Tdci) > Help- Puma 2.4 doesn't start |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Check underseay relays are secure and the the earths and battery clamps are tight $W33T $0U7H3RN $UG4R
10th Jul 2018 10:05am |
RubenCoelho Member Since: 02 Jul 2018 Location: Spain Posts: 6 |
As long as the battery is good, I even changed it for another one.
Now which relays and earthing terminals do you mean? You have to add an image or pass the exact position for me to check. Thanks in advanced. |
10th Jul 2018 10:12am |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Hi Ruben
Some questions: Do you have ligths or is completely dead? Check the main fuse located nearp the positive terminal of the battery Check the terminals of the battery are well clamped (both, positive and negative) as C90S said Check the fuse case that are in the seat box (rigth side) and see if one is burnt Check all the fuses in the fuse box located below the steering wheel. Try with that first. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
10th Jul 2018 10:54pm |
Hi Eduardo,
Answering your questions. Do you have ligths or are you completely dead? I have lights yes, if you notice the above post I added a video. I add one more photo of the panel. Check the main fuse located near the positive terminal of the battery Verified. Add the picture. Check the terminals of the battery are well clamped (both, positive and negative) as C90S said Verified. So much that I even changed for a new battery. Check the fuse that is in the seat (rigth side) and see if one is burnt Verified. No fuse burned. Check all the fuses in the fuse box located below the steering wheel. Verified. No fuse burned. thanks. |
11th Jul 2018 7:36am |
Hi Ruben,
Did you check it with a tester? I Realize in the video that the key doesnt have the alarm FOB. Do you have it with you when you try to start it? If not the alarm system will not allow you start the car. Put the FOB in the key ring and try again. Check this first. If not I will suspect othat you havce some truoble in the fuel line. regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
13th Jul 2018 2:33pm |
