Home > Tdi > Cracked cylinder head?
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Hi,
To give background: Bought a 300tdi for 50 quid last summer with absolutely no history/info. Chucked it in my 90 and it's been running flawlessly for the last yr covering approx 5k miles but pretty much all less than 30 mins and no motorway.
Yesterday, I went laning in the Dales which involved a decent stretch of motorway driving to get there. On the motorway on the way home the temp went into the red and it spat out all its coolant through the expansion cap. We weren't far off home so just chucked some more water in and gently drove home at no more than 50 ish. By the time we got home it had yet again spat out all the coolant.
I took the head off today and found this:
Cylinders 2 & 3 look to have cracks from the glow plugs and cylinder 4 looks to have a crack between the injector and one of the valves.
Additionally there are marks from the water jackets to the cylinders:
Do these pictures look characteristic of cracked 300 heads? Is a cracked head effectively scrap metal? Where's the best/cheapest place to get a recon or brand new head? Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #716720 8th Jul 2018 2:14pm
trickster5000
I've now had a better chance to have a look at the gasket and the block and it looks like the HG failed around the triangular-ish water jacket between cyl 2 and 3. This would explain the coolant pressurisation.
Additionally the small coolant hose that goes into the thermostat housing was completely blocked with cruddy deposits which means exhaust gases in the system from the HG failure wouldn't bleed properly causing air locks and overheating.
Before I spend £300+ on a new head I'm going to put a new gasket set on and just see if that fixes the coolant pressure problems for now and worry about the suspected head cracks when the symptoms arise. Matt.
Post #716793 8th Jul 2018 9:26pm
Mariner
Ireland
While you have the head off you may as well have it pressure tested.
The engineering shop will determine if it is cracked and they can clean up the mating surface. Not expensive and could save you some bother.
Post #716816 9th Jul 2018 12:53am
Procta
I wouldn't bother doing that, id just get the lot sorted out. You don't want to be pulling it to bits again. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #718145 17th Jul 2018 5:12am
