Home > Puma (Tdci) > Leaking water front passenger wing right at front
Hunky Gibbon01
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Zermatt Silver
Hi all. The defender seems to be leaking from the screen wash Reservoir because I couldn't find the source of any of the leaks. Has anyone had the same issue?
From a quick research on the website it looks like I might need a bottle cap but I don't know the part number or the size I think it might be 38mm.
Can I have a opinion, parts number and approx size of the bottle cap diameter?
Thanks a bunch HG.
Post #716320 5th Jul 2018 8:09pm
mk1collector
Washer bottle caps are available on eBay in black or blue Thumbs Up
eBay Item No. 292144315072 Ray
My build thread
Post #716321 5th Jul 2018 8:13pm
mk1collector
I’d get a torch and see if the pipes are pushed onto the pumps fully and the pumps are fully pushed into the bottle first though. Ray
My build thread
Post #716322 5th Jul 2018 8:15pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
My 2003 leaks when the washer bottle is topped up, so must be out of the cap. Initially I thought it was coolant but traced to the washer bottle, one of the advantages of having blue washer fluid and pink coolant. Thumbs Up
Post #716325 5th Jul 2018 8:35pm
Hunky Gibbon01
Thank you I've bought a cap anyway it's only a couple of quid. And will check the pumps thank you very much for advice.
Post #716331 5th Jul 2018 8:50pm
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
Being a tight was I cut up and old bike inner tube and made a gasket for my top and it's not leaked since
Post #716367 5th Jul 2018 11:23pm
zsd-puma
They have a breather hole in them as well as not sealing that well. When you fill it up to the brim with cold fluid, the fluid warms up and expands so it leaks out. It doesn't really matter though, it's not corrosive or anything and it's usually only a small amount.
Post #716369 5th Jul 2018 11:30pm
AndyT66
Thanks for that tip ZSD, I must admit I had a "oh no where's that coming from" moment when it first happened!
Post #716373 5th Jul 2018 11:50pm
As ZSD mentions above.
Mine does it too, and only when topped right up when fluid is sloshed about. There is a tiny little breather right in the middle of the cap too.
No problems or issues to worry about if it leaks a bit, it won't do any harm.
My washer fluid is apple green. Mr. Green WeWillWin🇬🇧🇺🇸
Post #716376 6th Jul 2018 12:52am
Laurie
Have you got air-con....?
Post #716377 6th Jul 2018 12:55am
Hunky Gibbon01
Yes i do.
Post #716594 7th Jul 2018 4:04pm
Laurie
Could it just be the ice melting from the condenser when you stop?
Post #716654 8th Jul 2018 2:13am
zsd-puma
condensation drain is in the middle right above the gearbox.
Post #716701 8th Jul 2018 12:02pm
Aircon does dump fluid, especially in this weather.
We used to have a Navara D40 that used to do it. WeWillWin🇬🇧🇺🇸
Post #716707 8th Jul 2018 12:50pm
