![]() | Home > Off Topic > Tdv8 manual gearbox |
6 pot Member Since: 01 Apr 2010 Location: England Posts: 53 ![]() ![]() |
Try Rakeway not cheap not quick but best quality
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
The standard ZF 8 speed has torque limit maps, the engine is capable of about 1200NM but the autobox limits that to about 800 via it's ECU.
So basically you need to find a clutch and gearbox that will take 1200NM (unless you have the torque limit set on the engine ECU) ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
