Home > Puma (Tdci) > Suspension - A softer ride required
Page 2 of 2 <12
BigMike
you might also want to have a chat with paul at west coast. he does the iron man springs and shocks too, there is a choice of foam filled or..the other one, cant remember which. they're cheaper than OME. if you have a look at the iron man website there are good explanations on there. the springs are awesome (I have the "B")
Post #71503 18th May 2011 2:08pm
BigMike
by the way if you do speak to paul, before you do send me a PM
Post #71507 18th May 2011 2:24pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Well, I would still say shocks make the biggest difference to the ride, IMHO, CLOSELY followed by springs, making the difference to the handling.
I changed the rear springs first on my 110, and although there was an improvement, it wasn't until I swapped the shocks that the ride smoothed out.
I suppose it still depends on where you're testing it! Near me, the roads are bumpy, potholed and the surface eroded. On this, the shock upgrade made the most sense. On really bumpy roads and off-road, I reckon the effect of the springs becomes more noticeable.
With my 'custom' rear springs from Extreme 4x4, and the Bilsteins, I now have a 110 that rides well on road (although I'm fitting a beefed up rear anti roll bar to sharpen the towing ability and directional stability), without really impeding its capabilities off-road (albeit the ARB might limit extreme off-roading).
BigMike wrote:
szracer wrote:
Shocks will make the biggest difference to the ride, followed by springs (particularly rear).
Then if you're feeling really flush, beefed up anti-roll bars.
Fitted Bilsteins on my 110 and the ride is transformed - Much more supple.
The fact that the OEM LAnd Rover shocks are £30-ish each RETAIL, gives you an idea of how much they cost to make! They're truly shi*e!
Actually on a landrover its springs that make the biggest difference rather than shocks.
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #71510 18th May 2011 2:34pm
Page 2 of 2 <12
