Home > Technical > Oil Leak - Front Axle Drain Plug |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Quick internet search seems to indicate 44ft.lb torque on front diff drain and filler plugs.
27th Jun 2018 6:40pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
brill... i forgot about google - just seen an old post on here that also states 44ft.lb
http://www.defender2.net/forum/post37497.html Will get the torque wrench out tomorrow and see if i am a wuss! its takes a couple of days of waiting to see if its sorted... plus a brick and some cardboard. |
27th Jun 2018 6:56pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 |
Hmm I think I have the same issue after switching to a magnetic drain plug earlier in the year. I'm confident I went past 44 ft-lb which isn't a lot when doing it up. I've just been turning a blind eye to it - its a lot less than the leak coming from the crank shaft seal anyway... 2005 Td5 90 XS
1989 V8 110 CSW |
2nd Jul 2018 12:10pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
I would try some PTFE tape on the threads. Make sure you wrap it around the threads in an anti clockwise direction (as seen from the drive end of the plug). Defender 90XS SW
2nd Jul 2018 12:18pm |
well it turns out i'm a complete wuss with regards to judging how tight things are I'd tightend up a little more and the leak changed from a drop on the drive to a droplet on the plug but after 2 days but no drip.
So i got the torque wrench out and turned both front a back a shed load more before hitting the set point. (i did put a bit of hylomar on the threads though!) Suspect its sorted - but will keep my eye on it. Such a small leak it took days to run down the axle before it then drops onto the drive. I only used the torque wrench for important stuff like suspention parts and cylinder head bolts; looks like i'm be torqing everything from now on just goes to show. Great Forum; Great advise |
2nd Jul 2018 4:09pm |
