Home > Maintenance & Modifications > Rear Steer assist
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
Rear Steer assist
I have a dream, part of this dream is rear steering assist.
I am looking to install rear steer assist on salisbury axles, with porta-axles.
The question is it as simple as bolting on the front steering components onto the rear axle?
Also do i have to get special porta-axles for the rear or it doesnt matter as they just bolt onto the output shaft...
If everything is compatible do i still retain the capacity or do i lose some capacity? I will probably be running the 500kg OME rear springs with the hd fronts to handle the extra weight from the OM606 engine.
Post #714662 27th Jun 2018 9:19am
jst
Hydro rear would the easiest actuation on std front swivels to suit your axle/portal setup. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #714670 27th Jun 2018 9:48am
jst
Plus a way of locking it straight. some use a rigid bar locking the ram in place. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #714671 27th Jun 2018 9:49am
Naf
I was thinking of creating a hydrostatic system that uses two potentimeters, one on the front steering box, and one in the rear for feedback. A steering pump with electronic valve. Have a speed input and program the system to do one of two options.
Auto, where below set speed the rear will steer opposite to the front, and above set speed will crab steer in the same direction.
Off, where the front only steers
manual opposite steer
Manual crab steer
Also have a bar in case of failure
But the is i add cv to the rear, how much capacity do i lose?
Post #714678 27th Jun 2018 10:19am
The "normal" way for implementing rear-steer on a Defender/Series is to take a front axle and cut and weld the axle tube to allow it to be fitted at the rear, then use a hydraulic ram for steering activation. It was widely done on trials vehicles back in the day.
Post #714683 27th Jun 2018 10:47am
