Home > Puma (Tdci) > 2.4 PCV valve part number |
I assume you mean Positive Crankcase Ventilation valve. In Which case it comes as part of the cam cover LR007754. To replace this you'll also need new injector washers, but the cover does come complete with gaskets and oil seals.
You're supposed to replace the injector pipes too, but in reality so long as you make sure you keep everything clean you can reuse them. |
25th Jun 2018 11:46pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 |
Thanks for that Puma 110" SW
26th Jun 2018 12:03am |
