Home > Maintenance & Modifications > Optimill 110 Window blocks
Big4
United Kingdom 2016 Defender 110 Puma 2.2 USW Santorini Black
Hi
I'm replacing my window blocks on a 2016, 110 Utility, the window block I've taken off don't match the bolt pattern on the new Optimill window block, RH on both blocks
Is it the new blocks that are wrong or am I missing something 2016 Defender XS Utility by Urban Automotive
Post #712869 17th Jun 2018 6:41pm
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
No you're not missing anything, you've been supplied with 2x RH blocks. They should be handed as per the top photo of the ones you've taken off.
You'll need to contact the supplier you got them from.
I had a similar issue but that was with OE style blocks.
Post #712872 17th Jun 2018 6:51pm
LR90XS2011
what he said DEFENDER 90 TDCI XS,
Post #712873 17th Jun 2018 6:52pm
Big4
Thanks guys, supplied in sealed bag from Flatdog, I'll give them a bell and hopefully get sorted, can believe how quick the window block corroded on a 2 year old car 2016 Defender XS Utility by Urban Automotive
Post #712899 17th Jun 2018 8:00pm
Vitesse
hope You get the correct blocks. I was aware of this issue before I bought my new 2015 90. Kept them clean with acf50 and also loosened them when new and applied dinitrol behind and in the threads etc. Worked fine and still perfect. But I agree that it’s a joke how sometimes they just corrode so quickly. Crying or Very sad 2015 90 XS Santorini Black
Post #714004 23rd Jun 2018 12:33pm
zsd-puma
Holes look completely wrong to me, they're central on the Optimill ones, where as they're heavily offset and as you pointed out handed on the originals.
Post #714028 23rd Jun 2018 2:48pm
Caterham
If I'm not mistaken they should all be in a straight line. Is the bracket on the inside that they bolt to not straight?
Post #714043 23rd Jun 2018 4:41pm
No, the blocks are handed and the holes are off-centre. Darren
Post #714094 23rd Jun 2018 8:40pm
jst
they are handed, you have wrong parts. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #714153 24th Jun 2018 10:01am
Huttopia
Like this
Post #714168 24th Jun 2018 11:28am
