Home > Technical > 300TDi Not Starting
Roosterrs
300TDi Not Starting
I still have the issue with my 300TDi Defender not starting intermittently. Turn the key and nothing happens. I have recently found that if I take the fusebox cover off and then push on the fuses, I can get it to start. The fuse box does have some corrosion on the drivers side, i.e white powder on the terminals, so I assuming it has got wet at some point.
I am not sure if this is the cause of the problem as I suspect it is the alarm spider, but has anyone else had this problem with the fusebox? How difficult is it to replace one? Thanks
Post #713858 22nd Jun 2018 11:54am
Huttopia
How bad is the fuse box? Pictures are always good. I had a G4 TD5 that had been on both trips, including across the salt flats. The fuse box on that was a bit on the crusty side. An hour or so cleaning up and it was fine.
Post #713860 22nd Jun 2018 12:12pm
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
Sounds very similar to a problem I had a few months back. I was recommended to install immobiliser bypass which cured the problem completely. Was easy to install as well just drill out the rivets, pry the box open and plug the bypass in. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #714289 24th Jun 2018 10:25pm
Roosterrs
It’s been a while but my 300 TDi has been starting fine ever since we had the hot weather this summer. So I am wondering if it’s damp related. Any one else had a starting issue disappear since we had the hot weather?
Post #731264 25th Sep 2018 10:32pm
NickMc
Your problem is most likely the fuse box corrosion as you’ve discovered.
Post #731868 29th Sep 2018 3:30pm
