Home > Td5 > TD5 vibration
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
TD5 vibration
My 06 90 td5 has developed a vibration which I think is engine related. Possibly flywheel? I’ve checked all the normal culprits like UJ’s and wheels balancing. No play in any UJ’s but could be a tight spot in one. The reason I suspect the flywheel is because when I let up the clutch pedal it’s evident.
It’s a permanent vibration but gets intermittenly worse. . I use it on the weekend but needed it this week so it’s become more noticeable on long journeys.
Any help would be appreciated ?i
Post #713250 19th Jun 2018 6:34pm
mk1collector
Does the engine squeak when you turn the ignition off? Ray
My build thread
Post #713265 19th Jun 2018 7:22pm
Alextd5
Hi Ray,
No squeak from the engine, I checked the crank pulley seems fine.
It’s just hit 70,000 miles so I’m reluctant to replace the DMF for that reason but I’m still convinced that’s the where the problemil lies. But want to be almost certain it’s that if possible.
I’ve read other posts and found flywheels can only last 60k? My other 90 td5 was on 120k before it was replaced and still didn’t cause any vibrations etc. But wasn’t worth putting all back together without.
Anything else I can check before I bite the bullet?
Post #713277 19th Jun 2018 7:47pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Had some vibration on my 65k mile td5 and seemed to be getting worse Pulled the propeller shafts one at a time and went for a drive. Found possible slight play in rearmost u joint, but still very good. I was convinced it was not the source of vibration, but while on the bench i pushed a lot of new grease through all the u joints....vibration now completely gone.
I do have a slight but intermittent 1:1 vibration when hot at idle in traffic which might be a DMF issue though, so watching this thread.
Patrick
Post #713286 19th Jun 2018 8:01pm
Alextd5
I will double check the UJ’s but I’m not convinced as when I let the clutch up i feel a vibration through the floor. Every so often I get it through the steering wheel which makes me think otherwise or two different vibrations. yes I know it’s a Land Rover !
Post #713296 19th Jun 2018 8:24pm
