Home > Maintenance & Modifications > MadMan EMS2 Installation
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Ready to pull the trigger on a MadMan EMS2. Problem is, where to put it.
Either add on the panel here with the round cut out.
I have a double din conversion, but also have my ebrake switch mounted under this panel, that will have to be relocated. I will also have to rotate this panel, and have the madman on the top so it can be seen, with the switches on the bottom, not sure how much extra wiring there is behind this panel for the switches? Anyone know
Or go with a MUD Puma Pod
Would be cleaner, anyone have a POD? Thoughts
Thanks
Mark
Post #709706 29th May 2018 9:59am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
And example of the round hole on top. Plenty of space for wires etc a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #709710 29th May 2018 10:17am
Bluest
I've got a Raptor Engineering dash top pod waiting to go on for some aux. gauges. Might be worth a look. Feels like a much higher quality item, as it is metal instead of the vac formed plastic Mud pod. 2007 110 TDCi Station Wagon XS
Post #709712 29th May 2018 10:23am
2010Blackdefender90
the Raptor does look much better than the MudPod, and I never liked the "splash" on the back. Thanks
Post #709715 29th May 2018 10:27am
smb
Looking at ordering the Madman2 and 2.4 sender system, but not sure of best place for installation. However, the place that seems so obvious would be to put it in place of the clock.
Has anybody installed it in this place or know of anyone who has done it? Does anyone have any photos? Im pretty sure someone has done it as it seems the perfect position.
Many thanks
Steve
Post #713133 19th Jun 2018 9:06am
2010Blackdefender90
There is a picture / image of someone out there who did that.... can’t find it now, think it was on facebook.
Post #713144 19th Jun 2018 10:49am
2010Blackdefender90
Here’s mine.
Post #713149 19th Jun 2018 11:25am
2010Blackdefender90
My dash extension will get covered in leather to match the dash tops and when I get around to it, the front panel will get painted the same as the rest of the center dash, gloss black... still wiring everything up, heated door mirrors etc... work in progress...
Post #713150 19th Jun 2018 11:27am
