Home > Td5 > Starting woes |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Grease tends to dry up in this weather so the starter gear mechanism could be binding.
Have you checked for voltage drop on cranking? Some will be normal, but below 7v you’ll have a battery issue $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Jun 2018 1:18pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
could do with some more detail, smoke on cranking? slow cranking? instant deterioration or over time steadily got worse? mileage? fuel pump noises? etc etc
could be fuel issues assuming battery is good, cracked filter housing and failed pumps are common. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
19th Jun 2018 12:32pm |
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 |
The fuel pump has been whining for as long as I can remember, 2 years or more.
No smoke. 90k miles; HG was done about 5k ago. Fuel filter replaced at service about 2k ago. Turns over easily and quick (i'll check the rpm when I get a chance). It only started doing this in the last couple of weeks (about 3 weeks after serving the solenoid on the starter - in situ, did not remove starter) The battery does lose charge over time and 3 weeks of no use will leave it unable to turn the engine over - there's a current draw on the battery of about 0.03A when off (from memory... although trying to remember if it was 30 or 300 milliamps) No loss in power. Starts very happily when hot/only happens when cold starting. Fuel gauge currently on 1/4 and has been unhappy last few times - will fill up tonight as I read somewhere about people suffering this on less than a half tank but not above. |
19th Jun 2018 12:49pm |
any noise from the fuel filter housing?
the pumps like to be kept cool with lots of fuel in the tank, is pump is weak or bleed back to the tank then filling cant hurt it. doesnt sound electrical my current vote is on fuel running back to the tank. if you prime the fuel system prior to starting (10pumps on accelerator with ign on) what does it do when you then try to start? its shouldnt go flat in 3 weeks. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
19th Jun 2018 2:27pm |
Does the oil smell like diesel or has the oil level risen? Noisey fuel pump and bad starting/cutting out while driving on mine was injector washers. Ray
19th Jun 2018 5:11pm |
Fuel pressure regulator on td5 top left side of cylinder head - check for leaks
19th Jun 2018 6:45pm |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 539 |
In case you need it...
“A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
20th Jun 2018 7:28am |
