Home > Puma (Tdci) > Fixing Dixon Bate 5T tow jaw to cross member |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
i would suggest a spreader plate behind the cross member BM52
16th May 2011 9:37pm |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 |
Thanks but it's got captive nuts so I don't think that's easily done. I'm more worried that the threads shall already be damaged / corroded.
16th May 2011 9:42pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6122 |
When I built my (Td5) 110, I had the chassis galvanised.
Of course, when I got the chassis back from the coaters, the threads were all blocked up, so i tried running a tap through the towbar holes (to fit a NATO hitch) but the theads came out very messed up, so in the end I drilled them out and tapped to M16 (factory size is M14) These fitted (just) through the hitch holes and made the whole thing a much tighter fit...the M14's seemed to rattle around the hitch holes |
17th May 2011 6:40am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
They are threaded and ISTR you will struggle to get a spreader plate behind, even if you could Mike
17th May 2011 5:10pm |
