Home > Puma (Tdci) > Flat battery now dead - can’t reprogram key
cartoonhead
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Corris Grey
I managed to run the battery flat on my 2.2, the lock and unlock buttons in the key don’t do anything now and when I try to start it the engine turns over once and then cuts out.
I figured I needed to reprogram the key but when I attempt to do that my GAP tool gives me error ‘E60’ - it seems for some reason it can’t communicate with the car immobiliser.
I have a aftermarket immobiliser fitted by audiofile as well but I called them and they said it only immobilises the starter motor and couldnt affect the LR in this way.
I’ve tried disconnecting and reconnecting the battery - makes no difference, tried a new batter in the keyfob also no difference.
Anyone have any ideas please?! @tab.travels on instagram
Defender 130 2.2 TDCI
Defender 90 TD5
80" CCV Trialer 4.6 V8 (14CUX)
Stage One V8 109 - 3.5 V8
Stage One V8 109 - 4.6 V8 (GEMS) - in progress
Range Rover L322 4.4 TDV8
Freelander 1 2.0 TD4
Post #711912 11th Jun 2018 4:50pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Post #711920 11th Jun 2018 5:34pm
cartoonhead
I did try that with no luck mate - turns out it was the fuse that had gone! @tab.travels on instagram
Defender 90 TD5
Post #712082 12th Jun 2018 6:10pm
