Home > Technical > Boost and Vacuum gauge help
Welkman
Hi all,
Fitted a nice STACK boost and vac gauge by tapping into the intake manifold via my erg replacement elbow.
The gauge is under reading and sticky.
Any suggestions? Do I need a separate feed to register vacuum and use the supplied T piece?
Thanks
James
Post #706178 9th May 2018 9:22am
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
on the intake manifold there is a 1/8 plug, remove it and insert a threaded barb fitting and take your boost/vacuum from the intake manifold.
Its near the MAP sensor.
Post #706899 13th May 2018 2:00pm
Hufflepuff
Erm... does a diesel engine generate a significant reduction in pressure below atmospheric?
Unlike in a petrol engine where there is a butterfly throttle valve which restricts air flow into the engine when closed, which in combination with the cylinders sucking air into them can significantly reduce the air pressure in the intake system, a diesel's intake is always fully open so you only have reduced pressure due to the restriction of the turbo and air filter? 2005 Td5 90 XS
1989 V8 110 CSW
Post #707080 14th May 2018 11:18am
rallysteve
Indeed, there should not be any vacuum registering on the gauge at all. The boost side will work nicely though.
Post #707085 14th May 2018 11:59am
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
If I may hijack this question, if I wanted to reinstate a boost gauge on my 3.9 EFI RR engine, where do I need to drill and tap for the barb fitting that goes to the gauge?
The old SD1 engine had a fitting at the back of the inlet manifold I think but not sure where I need to install it on this engine.......
Very Happy
Post #711878 11th Jun 2018 11:51am
