Home > For Sale & Wanted > [For Sale] Land Rover DEFENDER 90 TD5 1999/2000
Stupots1968
England 2015 Defender 90 Puma 2.2 HT Montalcino Red
Defender 90 TD5
1999/2000 143000 miles
New Galavanised Chassis as Pics .. done by RST Colchester.
Ebay listeing Number : Defender 90 TD5 (312144088003)
Fitted with Direct 4x4 Roof tent with awning down to floor with groundsheet.
Tent mounted on 4 x Rhino Roof bars, makes removal/fitting of tent easier.
Price drop ...
£10750 with tent / rack.
£10250 without tent.
Alive Tune stage 2 ( better mpg and smoother power not exessive)
Silicone hoses.
runs beautifully doesnt use any oil/smoke.
New Galvanised Chassis in last two years.
New Discs front and rear / brake lines / wheel bearings.
New Terrafirma shocks/springs fitted (2" lift") poly bushes also fitted.
New clutch fitted when chassis done.
Stainless steel Full exhaust system (free flowing) sounds very well without been offensive or loud.
Farm Jack with adapter for lift inc. All Pedal security lock.
DAB radio fitted inside cubbybox.
All Terrain tyres front ... Mud Terrain Tyres rear.
Comes with tent on detachable roofbars .. ( picture of tent is from direct 4x4 website who supplied tent)
3 man tent
Foam Mattress with cover
Zip on annex ( picture of tent is from direct 4x4 website)
Ground Sheet
Waterproof travel cover
Ladder
Window Hinges
Roof top fixings
Straps and ties
All fixings needed
Full instructions
Roof Tent Features:
The main section of the tent is made from expedition quality, oxford nylon material. There is a waterproof cover cover over the top of the tent to give it extra protection from the elements. The tent folds out neatly using a series of aluminium tubular loops. One of the loops mounts in place to form an entrance cover so you can go in and out but still be under cover. The mattress is is a 3 inch thick, high density foam with a green cotton cover (washable). There are 3 windows on the other sides of the tent. The windows also have an insect screen zipped in which can also be fully opened or not. The windows are firmly propped open with stainless steel rods. the base of the tent is aluminium coated ABS plastic. All the material is double stitched and the zips are wide heavy duty. The PVC outer cover is fastened in place with thick Velcro and 2 securing straps.
Annex Features:
One of the best features of the tent system is the zip on annex at the base of the tent. This provides a whole other room, which can be used to keep a kitchen, your wet or dirty clothing or other items. You even have enough room to sleep 2 children in there. The main annex is made from the same durable and waterproof material that is on the outer of the tent. There is 1 entrance and 2 windows to either side, these all have anti insect netting integrated, so you can have the option of fully opened, open with anti insect netting or fully closed. The rear of the annex has a single zipped exit into the vehicle, this means you can access vehicle without going outside. The Ladder forms the support for the tent and sits within the annex. It has a fully waterproof PVC groundsheet on the floor which is zipped together with the main annex. The material is double stitched and has built in straps to connect the guide ropes to.
Tidy and reliable Defender, usual marks scars to bodywork for a defender of this age.
All work done by RST Landrovers, Colchester.Including servicing and MoTs.
Post #710124 31st May 2018 11:47am
Sulisuli
What’s the price Whistle 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #710126 31st May 2018 11:55am
Stupots1968
bump ....
price drop ...
Post #710759 4th Jun 2018 5:32pm
Stupots1968
No interest at all "........ pointers please ... need to sell
Post #711656 9th Jun 2018 10:43pm
NickMc
Some good quality pictures would be a starting point in any advert. You’ve only got one of the car complete Thumbs Up Maybe add some information about service history.
Sometimes too much info is a killer too, is a very long winded advert with no pictures. Just stick to the facts.
Post #711660 9th Jun 2018 10:55pm
You've also got to bear in mind that you're pitching to a very limited audience on here, as most have already got one. Ebay or Autotrader will find a buyer more readily. Darren
Post #711666 9th Jun 2018 11:42pm
Djcla
Could be interested in the roof rack and tent if you looking to separate?
Post #711772 10th Jun 2018 6:52pm
