Home > Td5 > Swivel Bearing Housing replacements
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
Im about to overhaul my front swivel housings and suspect I will need to add new housings to the parts list.
looking at the prices for genuine against Bearmach and Brit part offerings which is a considerable difference need some advice as to which path to take.
Any bad experiences with the cheaper housings?
Advice always appreciated folks.
John 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #711402 8th Jun 2018 9:44am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I have had good results with aftermarket swivel housings. Teflon covered even... šŸ‘ 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #711421 8th Jun 2018 12:09pm
jst
i have fitted bearmach swivel houses in the past to 3 vehicles, longest was 6 years ago, they are still going strong. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #711425 8th Jun 2018 12:17pm
Alex1976
I rebuilt my swivels two years ago now and used the Britpart Teflon covered ones and they are still performing perfectly. The finish is all in tact and no issues to report at all.
Post #711428 8th Jun 2018 12:45pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Same here with the Britpart ones.... no issues 18 months later (knock on wood) Very Happy it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #711436 8th Jun 2018 3:04pm
JOHNT01670
Cheers folks - will take the less expensive route
Many thanks. 2006 TD5
Post #711449 8th Jun 2018 4:47pm
NickMc
If you go aftermarket buy the ones that say ā€œmade in Indiaā€ on the box. Doesnā€™t matter if itā€™s Britpart, Bearmach or all makes they seem to change suppliers - must just be whoever has the best deal on the order. Iā€™ve found the Indian remakes are better finished and a better fit.
Post #711453 8th Jun 2018 5:11pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
I replaced the left front with a britpart kit and it has been very good so far.
If ordering from Paddocks......bear in mind there are two kits..one with aftermarket bearings and seals and another for relatively little extra momey for one that uses OEM or Land Rover seals and bearings. Obviously get the latter. I was not aware and bought the inferior one, then spent a quite a bit more for the OEM bearings and seals from the dealer.....
When i do the right hand side, ill order the proper kit. ( whomever installed the right side last time, snapped the lower bolt that holds the steering stop and decided to weld it all together rather than drilling out the bolt remains......looking forward to that repair..šŸ˜
Patrick
Post #711469 8th Jun 2018 6:23pm
agentmulder
Kuwait
Can confirm the Britpart swivel housings I received and installed 2 years ago are still working like a champ.
It's one of the castings that they seem to do well with. Solved the bowel problem, working on the consonants...
Post #711532 9th Jun 2018 1:43am
JOHNT01670
Already got all the bearings, seals etc already (Timkin & LR genuine) was away for MOT yesterday and had a quick check of the housings whilst it was elevated and notice some pitting so decided to do the lot together.
She passed!! 2006 TD5
Post #711574 9th Jun 2018 10:21am
