![]() | Home > Puma (Tdci) > Air-Con Kit DA2344 |
Bergos Member Since: 08 Aug 2015 Location: Somewhere in Portugal Posts: 95 ![]() ![]() ![]() |
Hi.
Two years ago I had the DA2344 Air-Con Kit installed in my 2007 Def. I'm quite sure something is not right - for example the fan never kicks in. I am searching for installation instructions to check if everything is all right. Thank you for any help. ![]() Click image to enlarge Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
MGRGPGBG Member Since: 19 Dec 2017 Location: New York Posts: 67 ![]() ![]() ![]() |
https://seriesforever.com/es/index.php?con...achment=10
The link has the instructions as a PDF - this unit is made by Coolair Logan. I am installing this unit in my build right now. The instructions are not all that great, but at least you can try and troubleshoot it. You can also contact them as they are pretty good with getting back to you. I have been working through a few questions with them over email. |
Thank you a LOT!
BTW. How come you have a Puma Defender in USA? Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
Can you tell me one thing, please? The Electronic thermostat is connected to one of 4 relays. Which one? Is it the one that is powering the A/C pump or the fan? In my case it was connected to the pump relay and... the pump was not working. I've switched the wires and connected it to the fan relay but now the fan is never working.... Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
Replacing my 2.5TD on an 1989 D110 with a used 2.4 and puma bulkhead / dash
