Home > Td5 > New to me TD5, but seems down on power. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
First things first, put a quality new MAF sensor on it. Then go from there.
Welcome too |
4th Jun 2018 6:53pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2168 |
Get rid if the piggy back and get it mapped properly.
Get rid of the diesel dump valve for whatever ridiculous reason its in there for. New Genuine MAF Sensor - Gen LR - Siemens or VDO only. The rest are pants Clean the MAP Sensor - On the inlet manifold Check the air filter isnt blocked |
4th Jun 2018 6:57pm |
Nigelpugh7 Member Since: 18 May 2018 Location: Solihull Posts: 115 |
Unnecessary quote removed
Thanks for the welcome, have been active in the discovery 4 and and fullfat Range Rover forums, but been a whilst since we have had a defender like this to play with! |
4th Jun 2018 7:01pm |
Yep that’s ar first thought too! I think a new Genuine Maf will be the first purchase of course.. We have done a full Genuine filter and oils replacement already, so fuel filter, both oil filters, and of course air filter too.. |
4th Jun 2018 7:04pm |
Just unplug the maf and drive it about to see if some power comes back, if it does you need a new one. Ray
4th Jun 2018 7:24pm |
That’s our first thing to check in the morning, but thanks for the pointer!
4th Jun 2018 7:43pm |
Quick question of the diesel dump Valve if I may experts?
As it seems to be piggy backed with the Genuine Land Rover air control valve, what should the standard pipe routing look like? Anyone point me to the std layout please? Also as the valve, ( I assume it’s a BOF type) is in the intercooler pipe, will disconnecting it suffice, or do I need to buy a new pipe too? If a new pipe is in order, shal,we just get a complete new set of silicone hoses for the intercooler and turbo? The reason I ask, is I’m sure I can hear hissing, hence air leaks form some where? |
4th Jun 2018 7:49pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2647 |
Those ridiculous tyres will sap a fair bit of power.
4th Jun 2018 8:12pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Check the boost pressure of the turbo. Too high will cause problems as will it being low 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
5th Jun 2018 10:33am |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 |
Yes definitely check the MAF, just because it looks clean does not mean it is working. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS |
5th Jun 2018 11:08am |
Right guys, quick update from this mornings playing with bits.
I disconnected the MAF and it has made no difference whatsoever, no increase in performance, but no decrease either. Checked the power feed and ground on the MAF cable, all good. Checked the ecu return voltage with the plug reconnected to the MAF, only a few milivolts reading. So I think that looks like the maf is shot so will get a replacement one ordered. Also tried plugging turbo valve pipes, at tbothr valve in the intercooler pipe, and the control block too. That has now stopped the stupid hissing and boy racer Valve noise, so I think we can agree that’s got have not helped, so I will replace the intercooler hose and get rid of the value and controller all together. Thanks for the pointers so far! |
5th Jun 2018 11:11am |
Right, another update now after some further investigation and fettling!
It turns out we were down on boost pressure as that stupid turbo dump valve was letting all the pressure out at the point where it was Inserted in to the pipe. So a new intercooler pipe, and removal of the control valve and the car feels like it has twice the power. A quick test of fault codes using Auto Logic Diags revealed loads of air flow sensor faults. So fitted and brand new Genuine Land Rover MAF, and now the engine pulls cleanly even from very low revs. All in all a massive improvement. There is still the occasional hiccup when I’m in 5th at about 60 mph, on a constant throttle, there is a blip and it feels like the revs increase on their own for a short burst. We still feel like the dastek power box is not helping,,and think it might also be over fuelling the engine. Next thing to try is to remove that all together and just run with the std rover ecu, to see how iit performs then.w Thanks again for the advice and pointers so far. |
5th Jun 2018 3:26pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
May I suggest this special tool for your tuning box:
Click image to enlarge |
5th Jun 2018 5:06pm |
That does indeed seem like the best suggestion!
5th Jun 2018 5:47pm |
