Home > V8 > Fan / Temp Switch |
Blanc Member Since: 14 Jul 2016 Location: Suffolk Posts: 43 |
I've got an XEng XFan controlling a couple of fans in my 3.9 and it works fine.
4th Jun 2018 1:33pm |
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 148 |
Thanks Blanc . I'll have a look that theirs.
Did you use their standard switch (88-83 / 92-87 ) as it seems a little low for the V8? I was looking at the 92-87/97-92 as probably being best suited??? |
5th Jun 2018 8:39am |
I do use the standard switch and the unit is connected into the into the bottom hose. I have a twin fan setup with cowling from a Ford Mondeo which fits bizarrely well to the V8 rad.
To start with I had it wired to two fans for high and low temps but it got quite annoying with the ease at which the first came on. I now have both hooked up to the upper temperature contact and it seems to come on rarely and cool it down nicely when needed. The reading I did seemed to indicate it could be a bad idea to let the 3.9 run any hotter. |
5th Jun 2018 9:32am |
