Home > Puma (Tdci) > power upgrade
Cruiser100
power upgrade
Have the 2.4 tdci
Whats the first steps in a power upgrade?
Post #710014 30th May 2018 8:17pm
1) find your wallet
2) contact one of the tuners on here (BAS etc)
Post #710020 30th May 2018 8:35pm
zsd-puma
1. Make sure your Clutch isn't half knackered.
2. Upgrade the adaptor shaft from the gearbox.
3. Make sure the engine is in good order - injectors tight and not leaking, EGR valve closes, VCV in good condition etc.
4. Get in touch with BAS or one of the other tuners for a remap.
Post #710027 30th May 2018 8:58pm
Imax
I am due to get a remap soon and I was interested in this reply where it mentions "upgrade the adapter shaft from the gearbox"... is anyone able to confirm whether this is really necessary and why would it be required...?
Thanks in advance
Post #710473 2nd Jun 2018 5:05pm
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Mine was remapped by TD5inside and it didn't need any of that.
The adapter shaft was changed at the same time as the clutch.
No need to change it before unless it fails.
Fabio
Post #710475 2nd Jun 2018 5:12pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Alive have a dealer not too far from you Thumbs Up
N.
http://www.beyondperformance4x4.co.uk
Post #710478 2nd Jun 2018 5:31pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
bas map is fantastic. had mine for about 6 years and i still smile everytime i drive it.
then inter cooler ans hoses. exhaust. not done output shaft 72000 miles. usual clutch change at about 40000.
also been 100% reliable.
go for it. Cool 110 xs s/wagon
s3 swb soft top
Post #710491 2nd Jun 2018 7:33pm
zsd-puma
The clutch and adaptor shaft are known weak points on standard Defenders.
My point was there is little point getting one remapped if the clutch rattles and the adaptor shaft is throwing rust out the bottom of the housing, because the extra power will just make them fail sooner.
Post #710531 2nd Jun 2018 10:46pm
LR90XS2011
first mod without a remap (unless you are driving through water a lot) is the airbox mod, search on here. Makes a difference and costs nowt except about 1 hr of your time. DEFENDER 90 TDCI XS,
Post #710541 3rd Jun 2018 5:20am
