![]() | Home > Tdi > Some (LT77) gearbox help please gentlemen |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Take off top housing would be first. Port off call
HK07 Member Since: 15 Dec 2016 Location: Hampshire Posts: 752 ![]() ![]() ![]() |
Due to a clutch issue, we had to separate the gearbox from the engine again today.
The gearbox shaft is definitely spinging freely, it must be the transfer box, but what/how? We are going to leave the prop shafts off and start it up and see what happens. Any advice would be gratefully received. Thanks 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
May be a bit obvoius, but is the handbrake engaged? 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2734 ![]() ![]() |
One of the bolts that join transfer box to gearbox can, if put in the wrong hole, actually jam the transfer box gears. Would be worth checking that.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
Try switching the transfer box between low, high and in and out of diff lock too.
It maybe stuck in neutral. After all, you can have the motor running in a gearbox gear but the transfer box in neutral and no drive. Nothing to lose by trying it, but as you say with props off and somone to keep an eye out is easiest and safest. Good luck. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
All useful things to try - many thanks.
The handbrake thing did occur to me, but the drum is spinning. I will update when we figure it out. 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
