Home > Puma (Tdci) > 2.2 Puma Limp Home Mode |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Where about are you?
Id suggest getting the codes read to find out what it's unhappy about. You could be chasing a red herring with the old MAF faults that were logged. |
29th May 2018 11:53am |
MAF faults aren't necessarily caused by the MAF either, an EGR valve playing up can also trigger spurious faults.
29th May 2018 12:36pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 588 |
Check all intercooler hoses for tighteness and leaks these leaks show up as a maf map pressure difference.
Listen for a slight hissing under load as an indicator. A little soapy water around pipe joints can help find a leak. |
29th May 2018 1:04pm |
Do the intercooler too. Mine split and didn’t hiss but allowed enough out to trigger maf codes randomly
29th May 2018 1:06pm |
benh78 Member Since: 29 May 2018 Location: UK Posts: 15 |
Thanks I’ll check for leaks I’ve also got a maf and charge air temp sensor coming just in case it’s one of those.
29th May 2018 3:00pm |
Where in France are you
Anywhere near the limousin region? If you are and get stuck I have a basic gaff with beds and shower that is available. Good luck getting sorted. |
29th May 2018 3:50pm |
We made it to our campsite in trinite sur mer in Brittany all ok just keeping the revs above 3000 but thank you for the kind offer.
29th May 2018 4:25pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 502 |
Hi there - if it's a 2.2 take a quick look if the DPF sensors set loose. Bonne chance! |
29th May 2018 9:25pm |
Hi All
It got us back from France all ok and it turned out to be a split in the intercooler near one of the ends it was repaired under the extended warranty. Ideally I’d like to upgrade the intercooler and hoses but there is prob no point while under warranty as the dealer only uses genuine parts. I would really like to add a third party cruise control but I don’t know if that would invalidate the warranty. |
17th Jun 2018 7:59am |
