Home > Maintenance & Modifications > Defender triple wiper setup
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
I saw online a while ago about a defender with triple wipers (all 13" standard wipers used).....
I am looking at the same mod but was looking at a 110deg sweep angle - (i think they used a 105 deg) just want to make sure i don't get the wipers bashing against the edge of the windscreen seal before i drill..
any idea who has done this mod- any 1 with a cad file?
Post #709497 28th May 2018 5:20am
ericvv
Post #709498 28th May 2018 5:48am
itolond
morgan?
Post #709500 28th May 2018 6:08am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Yeah Eric, Morgan? Never seen a single wiper on a Three Wheeler! 😂
Post #709501 28th May 2018 6:14am
grafty99
Morgan Plus8 Whistle Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #709503 28th May 2018 6:22am
discomog
The three wipers fitted as standard to the Morgan Plus 8 are absolutely useless in anything heavier than light drizzle. The photo proves the point I think. (I must point out that this is NOT my Plus Cool.
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #709510 28th May 2018 7:03am
It should be easy enough. Add a third wheelbox. Cut the guide tube for the drive rack at the appropriate places and flare the ends of the tube to suit the wheelbox. To alter the sweep either obtain the correct drive wheel or drill and bush the existing one to suit (the sweep is altered by changing the throw of the crank).
This was a popular mod in Series days, along with a one piece screen, and isn't difficult in principle.
Post #709511 28th May 2018 7:43am
It used to be a pretty standard thing on comp motors, though easy to do as there's no original bulkhead
Post #709513 28th May 2018 7:49am
ickle
Biggest problem will be finding the wheel boxes. Years ago scrapyards were full of minis, maxis. Jags, etc that use the same wheel box but have different sweep angles stamped on them - I did something similar with my buggy wipers parked along the header of the windscreen but the motor was down in the dash.
Good luck
Post #709525 28th May 2018 9:47am
zsd-puma
As Blackwolf said the sweep angle is determined by the crank in the wiper motor gearbox.
The wheel boxes are all the same. They're literally just a spindle with a cog on the end of them.
Post #709540 28th May 2018 10:51am
ickle
It's also determined by the lateral movement of the cable and the size of the gear in the wheel box, hence the degree marking on the wheel boxes.
With one motor you can have two different sweeps
Post #709546 28th May 2018 11:12am
Quite right, but if you want all the arms to sweep the same the motor gearing is the easiest to change.
Post #709557 28th May 2018 12:20pm
itolond
thanks for the feedback - my rig is a completely new mod- I wont be using the wheel box or the drive mechanism (OEM)
i am replacing the wheel box with 3 x sealed bearing / brass / 316 setup whilst using the 'traditional" STC987 so all the wiper blades and arms remain stock.
wiper motor is a heavy duty MRV marine wiper which should match/exceed the stock LR wiper motor but not have the park problems over time.
the setup will be a totally new rig- using bearings and connector arms. As stated i managed to do a motion study on solid-works and found the right linkage etc to give me just the right angle- so i can use 13" blades.
Post #710597 3rd Jun 2018 3:26pm
Wow! Why not fit three Kent Clearview Screens? Rolling with laughter
Post #710661 3rd Jun 2018 9:48pm
