![]() | Home > Off Topic > Oil fired cooker |
nick345345 Member Since: 05 Dec 2016 Location: Dunbar Posts: 71 ![]() ![]() ![]() |
Hi there, I've got an oil aga, it's the only cooking appliance I have, no microwave, kettle, toaster. Run it all year round. It can be a bit warm in the summer, but then I live in Scotland so not too much of a problem
![]() Mine has a back boiler so apart from really cold days of the year I don't need the heating on. Aga is enough to heat the water and keep the kitchen warm. Log burner does the lounge. Probably need to factor in servicing it twice yearly to keep it running well. Last couple of years I've been doing it myself, and I'm no technician. Once you work out what ropes and wick you need, and the general principles it's simple enough. Plenty of help on the web. And be prepared to get a bit messy when doing it... Having had an aga for 6 years I can't imagine not having one now. It's not the cheapest think in the world to run, but worth it for me. |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Another suggestion would be to buy a Calor Gas cooker and a couple of 47Kg Calor bottles, simple pipework to outside.
Electric AGA's are eye-watering expensive a single oven circa £2,500 double oven circa £3.500-£4.500. Whereas a Calor Cooker top of the range will set you back about £250.00 Two large Calor bottles will last all year even longer depending on how much you cook. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
depends really on the budget to buy. i wouldnt have an electric style aga which i think is what you are eluding to?
calor gas bottle cooker is good suggestion. i have oil fired aga, run it all year, service it myself once a year, it does my hot water too, uses 4-6L a day, we use that and log fires through the winter to keep house warm. benefits, you always have somewhere to dry stuff, it cooks much better, you never forget to preheat the oven, kitchen and rooms above are nice and warm, keeps residual property temp up. downside it uses oil daily! servicing is quite straight fwd. Also worth looking at the on demand oil nozzel cooker, their name escapes me currently. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2673 ![]() ![]() |
Many thanks for the advice, electric aga is not on the cards currently, heard they are horrendously expensive to run.
We are down to an electric range cooker or oil fired aga. Cost is a consideration but not a determining factor 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
you can pick up oil fired Agas none refurbished for £250 in some papers if your not in a rush! Cheers
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
I run an old Reyburn on oil. It has a wick and therefore does not need electric to power the blower, just something to think about if power cuts are likely to be an issue. 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
Thats good to know. ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
We run a Stanley oil fired “Aga” & an electric hot plate & oven.
Stanley gets turned off in the Summer & we use an electric immersion for water. IF I was starting from scratch I would go calor gas either off 47kg cylinders ( we use these for our cabins/kitchens on site) & we pay about 20 quid a cylinder delivered OR a Calor tank. Agas & hot summers really don’t go together in my experience Guy May your life be like toilet paper ; long & useful. |
Toby60 Member Since: 06 Dec 2014 Location: Cheshire Posts: 28 ![]() ![]() ![]() |
We also run a oil Aga but we turn it off in the summer because it gets too hot in the kitchen and use an electric cooker and hob. The Aga is also expensive to run but at least in the winter it heats the room as well as cooking.
I would favour the Calor Gas cooker and hob as it’s cheap to install and economical to run compared to oil. I would run this from 2 x 19kg Calor cylinders on an automatic changeover valve, ie it runs on 1 cylinder and changes over to the other one when empty allowing you plenty of time to get a refill. One 19kg cylinder would probably last for a couple on months. ------------------------------------------------ 2002 TD5 90 HT County |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
Same here. We have an oil fired aga and have to turn it off in the summer or it gets much too hot but we also have an electric oven and separate hob so it's no problem. However I think we will put in a calor gas hob soon for wok cooking and also change our oil central heating for air source. Still trying to decide whether to keep the oil aga or swap for electric or wood.
We fitted An esse range,oil fired runs central heating, water and cooker, moved since but still miss it
Esse, that's the one I was thinking of Cheers
We were looking at installing an oil fired aga but the more we looked into it the electic total control aga is a great option. Every oven and hot plate can be turned on individually, you can set it to slumber to give a gental radiant heat in winter and you also get a controller with it to turn the ovens on and off twice a day.
That teamed up with a wood burner allows for heating in the. Kitchen area and an additional cooking location should we lose power. Russell 2011MY 110 XS USW Black Last edited by BigRuss on 28th May 2018 7:17am. Edited 1 time in total |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
‘a genital radiant heat’
You can’t beat taters done on the Aga ![]() |
