Home > Puma (Tdci) > Strange dashboard behavior. |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 |
Ok this is new... at least to me.
I have an October 2007 110 Utility, regularly serviced and with all recalls made. This morning i was driving around Reading when... i notice the dashboard all illuminated and the light's light in the dashboard on like if my headlights were ON. I check the switch and the lights were OFF. I lift my foot from the brake pedal and all dashboard lights turn off. I push the pedal again and the night lighting is on again (including cigarette lighter and radio). Now,i haven't touched any cable, the brake lights work flawlessly, the car runs like a clockwork. Has anyone experienced anything like this before? Thanks for any hint! |
14th May 2011 12:19pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 |
Not that one, but sounds like an earth issue. Puma 110" SW
14th May 2011 12:39pm |
Ok i will take the lights apart later today and check the connections. Please go on with the suggestions
14th May 2011 1:01pm |
That is right. Make a test with a wire and do the connection between the negative of the brake light with some good spot on the chassis or the bolt/nut that holds the plate light. Puma 110" SW
14th May 2011 1:08pm |
And so it was. A faulty bulb creating false earth contact. Thanks for the hints
14th May 2011 4:51pm |
