Home > Technical > Grommet
williamthedog
Grommet
Does anyone no the part number of this grommet. As you can see its just below the light switch. I found mtc 1650 but if someone has got the correct number it would be appreciated Thumbs Up
Post #708609 22nd May 2018 4:12pm
dorsetsmith
Sealing Bush,25mm diameter
Body / Batteries & Harnesses
Part code
14A7081
Post #708613 22nd May 2018 4:21pm
williamthedog
Thank you for that. I had a funny feeling you would be the first person to reply. Thumbs Up
Post #708617 22nd May 2018 4:43pm
Procta
will, have a sniff about the scrap yards for rovers, As that looks the same grommets that rover use Thumbs Up If you can find a metro, that grommet is found behind a the rear bumper, ( where the left hand fog light is) ( not sure I have one spare some where) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #710718 4th Jun 2018 12:16pm
williamthedog
I've sorted it now but thanks for that, next time I'm in a scrap yard I will acquire some spares 👍
Post #710720 4th Jun 2018 12:39pm
zsd-puma
they're just generic 25mm grommets, most autoelectrics places do them. Or Halfords likely do them in a small assortment box of grommets.
Post #710729 4th Jun 2018 2:04pm
NickMc
Probably cheaper in the dealers than Halfords these days Shocked
Post #710810 4th Jun 2018 8:46pm
