Home > Td5 > Two new front calipers soft pedal |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 919 |
Thansk for all the views and help... Not! RESULT: Brand new in box caliper was partially seized. 🤬 Had to rebuild a new caliper. Sad state of affairs when new parts can’t be trusted 😢 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
21st May 2018 9:00am |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
Did you use DOT5 or DOT5.1? I'm hoping 5.1.....
If you flushed through DOT4 with DOT5 you will have started a fairly aggressive reaction between the fluids in your brake system that leads to corrosion and the creation of solids in your lines and calipers. Unless filled with DOT5 from new, it's NOT recommended that you perform a swap. DOT5.1 is compatible with DOT4 - however most decent DOT4 fluids have boiling points as high as, if not higher, than the min. spec for DOT5.1 A bit of googling found the following:
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
21st May 2018 9:06am |
If you have used DOT5, buy yourself 5l of DOT4 immediately and start flushing..... You may still expect to have problems with your ABS pump and with your calipers so another flush may be needed
21st May 2018 9:18am |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
How did you bleed the system, two guys, one pressing the pedal and the other opening and closing the bleed nipple? Or did you go with pressurized approach? |
22nd May 2018 5:50am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7983 |
only just seen this and was going to reply but i was too late and have been told anyway! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd May 2018 10:44am |
No oressure bleed just the old fashioned way. All good now, deffective part out of the box. Re-bled entire system with a couple litres of DOT 4 to get the DOT 5 out. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
22nd May 2018 5:40pm |
23rd May 2018 10:16am |
